P
Problem Child
Guest
Ok guys, an old guy comming back from the dark side (Chevy) and wanting to show my son and his Camaro a few things. I have a 76 Dart Swinger and a 360 that I am getting done very soon. The following is a list of mods I will be making, so let me know if I am headed the right way to spank some chevy butt.
360 bored forty over
Speed Pro pistons for 10:5 comp
Eagle I beam rods
Lunati Bracket Master II Cam and lifters( 488 lift/235 dur)
Magnum Heads from a 98 Durango
Mopar Perf Pushrod kit
High Vol oil pump
Edlebrock RPM Air Gap Magnum Manifold
Holly 750
B&M 2500 Converter
Improved 904 trans
3:90 or 4 something gear
This deal is almost like the build up in Mopar Performance Mag on a 318. The extra cubes and compression should be a little better though.
Also, do I need to change the drivers side motor mount from the strock 318 and if so , where can I get one. Thanks in advance for your comments.
Eagle I beam rods
High Vol oil pump
Holly 750
B&M 2500 Converter
Improved 904 trans
