[SOLD] LA Solid Roller Camshaft
mopowers
West Sacramento, CA
Lightly used small block LA Comp solid roller camshaft. Was swapped out for a smaller hyd roller. Cam is in great shape but does have a couple small scuffs on the snout where the timing gear rides (shown in photos). Timing gear slides on fine, so this is a non-issue.
Part #70-240-9 (https://www.summitracing.com/parts/cca-20-740-9).
Complete specs shown in the photo of the card. 248/254* @ 0.050", .576/582", 110* LSA
$250 plus shipping from 95691. Check, mail order, or PP friends and family. Will ship promptly after payment clears. Local pick up from West Sacramento, CA works too.
Thank you!
Additional photos. Let me know if you have any other questions.
I believe the cam is on a SADI core. A stock-type iron distributor gear was run with this cam when it was run.
I also have valve springs and lifters available.
