last weekend, under hood with motor in, today trunk
mikess68
Portland, TN
got a little help from my friend chris next door, after sanding and cleaning etc, spray time..
A little help from a friend sure can make for a good day :cheers:
Looks like you are having fun 8)8) Looks great !!
looking good. now i see i need to get to work on my 71 Plum Crazy..
started today on sanding hood (took longest, already did angle grinder and wire brush on rust) trunk sand, then cleaned down the trunk (already had interior etc out) with laq thin, then klean wax remover, then started spraying. used 1qt of acryl enamel (will do body in color, clear poly) will try the doors and jams next weekend. still have to put dash and under hood back together but will replace trunk lid and hood to keep that areas clean while doing body work. tks for the kind words, it helps to keep me going. :)
