whitepunkonnitro
Removed from a 74 with a Slant and Air, so should be the same as a V8 as far as diameter goes. Have the bar itself, the brackets that mount it to the K Frame, the brackets for the bushings and the links (need rubbers, same as shock absorber tops). Everything you need to mount the bar except the control arm tabs, and they are available through the aftermarket. Asking $100 plus the ride. PM me if interested. Thanks FABO!
