Late model master cylinder fittings?
Evan Dutch
North Carolina
Hey guys,
Finishing up the 4wheel disc brake swap on my 71 Plymouth scamp. Not sure if the fittings I have in the late model aluminum master cylinder are correct. I’m using the one pictured below for the rear port, I’ve tightened it a good bit but I swear it seeps a small amount from the threads. Is this the correct fitting to use? If not, where can I find the right ones?
Thanks!
You can clearly see you have the one on the right. You need the style on the left. Your thread pitch is also wrong . It will fit but loose. Jus buy the master line set for your car from inline tube. Or ebay below
67-72 Mopar A Body Manual Brake Disc Or Drum Master Cylinder Line Lines Oem | eBay
You can see the tapered section in the fitting I have in this picture. I can’t use the line set, the linelock requires a handmade line
