dirty white boy
50 yr old Juvenal delinquent
new class starting up in my area and got 2 rolling chassis i need to use up and want to do it with mopar style so question is, tracks are from 3/8th to 1/2 mile dirt most with moderate banking! what would you build, how would you build it and why?? know its against rules but tech is sketchy at best, so roller cams and stroker cranks is viable options as most other will be cheating to. plenty of room for what ever headers and distributor and what not as well. so magnum? LA?? 89/90 LA rollercam???
Sportsman Engine Rules
1. Standard GM 350 production engine,or ford ,dodge with the same engine specs as chevy......as in cubic inch ,etc ....
2. Front spark plug inline with top ball join 1" tolerance or stock location .
3. Max. Overbore .060 GM #s 041, 186, 291, 461, 462, 492, Bow Tie out of the box OK, , no porting or polishing only machine work allowed is valve job, and head surfacing. Vortec, Bowtie Vortec, World Product Sportsman II 200/64cc, and Dart Iron Eagle Platinum 200/64cc allowed (World Product & Dart heads must be cut no less than 60cc combustion chamber)
4. Aftermarket Valve Springs OK (Two per cylinder - Max. 2.02 intake - 1.600 exhaust)
5. Three angle valve job OK (no titanium valves)
6. Forged or cast pistons, flat top or dished. May not protrude from cylinder bore. No domed pistons. Any type of piston rings, any type wrist pins, may balance.
7. Crank stock stroke 3.48'' and min. 48 lbs. Rods 6.0''MAX stock or steel rods OK.
8. Intake (ANY 4 BARREL INTAKE UNTOUCHED).
9. Adapter plates are allowed. May run 2'' spacer on 602 gm crate motor. May run 1'' spacer on performer 2101,7101
10. Carburetor: ANY 600 cfm or smaller. ANY 650 Carburetor allowed (choke horn may be removed.) Venturi and Base must be untouched!!!
11. Any fuel pump
12. HEADERS ANY (NO TRI-Y'S)
13. Solid or hydraulic cams and lifters with Roller rockers Ok, Screw in studs OK. Cam driven by chain only.
14. Wet sump only. Internal pump only, Oil cooler OK.
15. Stock types or MSD type ignition Ok.
11. Any fuel pump
