Late model wheel fitment
smythge
65 with a BIG BLOCK
Does anyone know if there are any late model cars that have the same bolt pattern 5 hole 4". I am looking for a cheap set of wheels I can put on my Dart and possibly pick up at a junk yard
I know a sbp wheel will fit on a 91 dodge caravan. The backspacing is wrong but it got us to the tire shop. Using those wheel will have too much backspacing probally.
I just did a quick metric conversion....4 inches = 101.6 mm..... they do use a 5 x 100 mm bolt pattern on some newer cars..... might be worth looking into ? anyone try this theory out yet ? it may be a new source of wheels for the sbp.....
Steel wheels seem to go on ok, as the holes get ovaled out slightly, but an aluminums wheel won't go, I tried this last year. I thought it would be a cheap way to get 15's on the small bolt pattern. Another thing I found is the center is a lot smaller on the FWD rims. I couldn't get the FWD rim to fit over the center of the 8 3/4. But I only tried FWD Mopar rims I had lying around.
