LCA Bolts
sabre67
B.C. Canada
Are the LCA bols available to buy new?If so where thanks group (1971 Duster)
Ño I mean the bolts that go threw the lower bushings.
I'm sure you are talking about the LCA pin. One on each side presses into the LCA bushing and then the arm. Other end attaches to K frame. They are available aftermarket.
I've got a couple that already have new LCA bushings installed. They are ready to press into your LCA (assuming the old bushing outer shell has been removed)
Im working on a 71 Duster,will they work on that year? and what do you want for them?. Any pics of them thanks
