[WANTED] LCA
leechris81
Monett, MO
I have a '73 Swinger. I have removed the entire front end (steering and suspension) for a long overdue refresh. New bars, bushings, TRE's, Pitman, idler, etc. In disassembling the car, I found that my left lower control arm has the tab for the sway bar. The right side does not. I would like to go back and put a sway bar at a later time. Does anyone have a left lower arm with the tab they want to sell? Thanks FABO!
F.Y.I.
I would tell you, and recommend, that you just buy reproduction mount tabs from Hotchkis, and just weld the repop tab onto your existing LCA.
