LD340 or RPM copy??
737jetdr
Martinsville, In.
Is anyone running one of these stage 1 summit intake manifolds? I borrowed the picture from ebay.
!Bjl5htwBmk~$(KGrHqUOKjMEsnr2+M8!BLUModuHjw~~_35.jpe
Closer to a Weiand Action plus copy.
The Weiand is a good intake, Action Plus or Stealth.`
How the Summit is, I don't know.
Heres a few LD-340 shots, stock and modded carb pad as per MoPars engines booke.
Where are you going to mount the coil if it's currently on the intake? That intake has the runners reversed from an LD340.
Hard to beat an LD340, darn good intake.
And here's a thought i ordered a summit stage 1 intake, For my 71 dart my hood wouldn't shut, Even with no-aircleaner lucky i checked it before i bolted it on, I have a stock hood , you might have something that'll work. I got my coil mounted on the firewall, away from the engine heat
