DesertRat
Leading edge boomer
Had my LD4B machined, trued and ready to put on the engine. Last night I set it on and about had a panic attack. It would not seat up, thought I mis-matched the generations. Turns out the block has roll pins front & rear for indexing the stock intakes. The Eddy does not have the holes for the roll pin indexing. When I slide it back, it fits perfectly so I guess I will be removing the pins from the block upon installation of the intake.
DR:coffee2:
DR:coffee2:
