[Found!] Leaf Spring Mounts - 69 Dart
billsdartgt
Puyallup, WA
When I picked the blue mutt up it already had the rear leafs moved inward on the axle and the original mounts front and rear are gone. I hope to be able to find the stock mounts cheap to see what the springs look like in their original position. Let me know if anyone around has some. I do not have any pict as I am not sure what they even look like
9/16 - see picture 5 in oldmanmopars post for the brackets I still need, they attach the shackle to the frame mount
I have a set of 3 way adjustable front mounts I am getting ready to put on my car. I will have the originals available when I get them off
first three are the front mounts , Forth is the rear mounts. The last two are the brackets that bolt to the mounts
Thanks oldmanmopar, picture 5 shows the bracket I need attached to the shackle, found the front mounts and some new shackles.
I have a bunch of nice sets like pictured. I want $40 plus the shipping . The factory clean bolts included. I do not store junk. I use the mounts with rusted tubes to weld in larger Diameters for Super Stock springs they get a larger bushing used in B-bodies
Thanks for all the replys, pms and info, I have the parts I was looking for on the way. I hope I am able to use them as planned LOL
