tcp710
- Joined
- Aug 21, 2005
- Messages
- 65
- Reaction score
- 0
So I had been getting my 67 valiant ready for a 6hr road trip, thought I had it all ready to go. Drive it to work and back as a test drive, when I notice the rear drivers side exhaust manifold bolt is bubbling.
Seeing that I just rebuilt the engine, I thought this bolt may have shook loose and just needs to be tightened. I was wrong. The threads were stripped. That was over 2 weeks ago, now I have lost all motivation.
Not really looking forward to tearing the heads off to fix this problem. I think while I am fixing the one with a threaded insert, I might as well fix all 4 that go into the water jacket (both heads), because if one is bad, the chances that the others are bad too. I only want to do this once.
Has anyone else done this without pulling the engine? I was planning on just removing the carb, intake, rocker arms, pushrods, then the heads. Fix the heads, then reassemble in reverse order.
I am not a fan of heli-coils, so i was going to use EZ-Loks, similar, just different.
