Finally got the rear brakes torn apart and the driver rear is definitely leaking.
I took some picture before I went to work but I forget where i put the camera at the moment.
How hard is it to replace this seal? I did some research and is looks like i should be able to just pop out the axle and remove leaking seal and install new seal.
Depending how much of a pain it could be I might let a shop do it once I finish the brakes as its just a little cold outside right now.
