thanks , I'll try that. take yoke off and apply silicone to the splines and put yoke back on and let dry I assume ?A little silicone will cure it. Kim
Stick ,by this.... what rear end ? There are no magic wands ,man ..I just did my pinion seal and my leak is gone.
A. you have the wrong seal
B.you damaged it putting it in
C. the area was/is still dirty before installing new seal
D. the pinion has a groove worn in it
the reason I didn't mention sealer is because mine already had sealer on it out of the package so I assumed yours did toothanks , I'll try that. take yoke off and apply silicone to the splines and put yoke back on and let dry I assume ?
Thank you for your reply.. When I take the driveshaft off I will check all the above.. Little leaks can test your patients.the reason I didn't mention sealer is because mine already had sealer on it out of the package so I assumed yours did too
