[WANTED] Left hand thread wheel stud
Contact Craig , member name mobileparts
He has new / NOS studs. I bought NOS left & right thread front disc brake studs for my 66 Cuda F/S ...7/16" thread
Easy transaction
@mobileparts
I'd have to think no one is making them any more so whatever is out there is NOS.
Used to be able to find them at better parts houses like big A or Napa the autozone advanced auto chinesium junk stores not so much.
i know coker had the lug nuts for them.
Specify if drum brake studs or disc brake studs. They are different.
Left hand thread on the rear tire
Sorry, I was questioning RRR saying that ORileys had them (lug STUDS) in stock.
I edited my post to represent what i was questioning of rusty.
im all into LH threads, my 67 still has all 10 on the left hand side. I was questioning the availability of NEW LH lug STUDS. ( Regardless of disc or drum, front or rear)
BTW I might have 1 I could spair, might be used if you are ok with that. I will have to pull the tote down to know for sure.
That would be great.
hey while we are on the subject what are the correct nuts for the small bolt ralleys are they the capped nuts or are they like a mag wheel nut?
They are a closed-end long chrome hex, with a round end with a very shallow cone. 7/16-20, 3/4" wrench size (they look similar to the very long ones used for the bolt-thru wheel covers). There are also 13/16" versions around, that have a more rounded end. They have more meat on the seat and look fine. Both are RH and LH thread. Not sure if you can get the 3/4" ones new any more — mine are all pretty beat.
I think the LH studs are still listed in the Dorman catalog which you can find online. Different for drums and discs, as someone noted. I have at least 5 LH rear axle drum studs that I pulled, and probably some K-H disc studs as well.
(What looks like rust in the knurl is copper colored metal)
All 3 have good knurls
1 is in great shape
1 is on good shape
1 had a bit more rust on the threads
All 3 i wire wheeled the thread section and was able to spin on a lug nut.
Compared to my 8 3/4 A body axles i am 99.9% sure these are rear studs.
Disclaimer.... I bought these used. I have no idea what type of life they had. They are yours free just pay shipping.
Pm me for the shipping details etc.
As ZooKypr as indicated to you --- I have *** NEW ***
N.O.S. *** ONLY *** LEFTY Wheel Studs.....
P.M. me, as per forum rules, if interested.... Craig......
