LH wheel studs
itsdiz
Active Member
New Mexico
I saw where someone else posted this question a while ago, does anyone know where to get 7/16x20 left hand thread wheel lugs? The PO of my 1965 Barracuda changed the LF wheel to RH threads. My guess is he broke a few before he figured out they were LH. I would like to switch them back. I tried robbing some from a 1970 Dart but the knurl is smaller. FYI the knurl is .555 in. diameter. I have been searching the internet, but no luck, everything I find is RH thread.
How many do you need? I think I have some. I swapped out all of the LHT studs on my 69 Barracuda years ago. They might be the same.
If the 70 Dart studs wouldn't fit his 65 your 69 studs probably won't either.
New replacements aren't made. You might get lucky enough to find some used ones but you need to start a parts wanted ad for that. Marketplace forums.
