diymirage
HP@idle > hondaHP@redline
No boosterDo you have a booster?
What returns your pedal?
The point I am working toward is this;air is compressible.
If you have an air bubble in there, it becomes a big spring, and perhaps, without a booster, the pedal will not return to its parking spot, which will keep the compensating port closed, which will prevent the pistons from retracting, which will cause the pads to drag..............
The power booster has a big spring in it,powerful enough to return the pedal.
Just put a toe under the pedal and pull it up. If it moves, there's your problem. If it doesn't;sorry to have wasted your time. But before you put me on your ignore list, go check the master cylinder for a fountain at brake release.It better be there! Try not to get fluid all over everything.....The fluid should also roil on pedal application, as the compensating port does it's thing.
Also, no fountains anywhere
Everything I could see was dry
I popped the line of the master and no spray there iether
Put it back on, and everything seemed to work as it should
Then the new one came in the mail, so I installed that one
A few things I noticed, the new one engages LOUDER then the old one
It was also considerably easier to blow through the new one then through the old one
I got a few miles put on the car and everything seems to work as it should BUT I think I may have popped the rod out, that connects the brake pedal to the master, should that just pop right back in?
Oh, and the line lock does seem to do this...
