wafastr
Active Member
I am doing the s6 to 360 swap in a 70 Dart, column shift. I have the original s6/904 column shift linkage, chassis to trans cross linkage bar, and a throttle cable/trans bell crank bracket and the threaded kickdown link from a v8 with the upper bell crank set. As for the kickdown linkage, I need the vertical link that snaps onto the upper bell crank pivot, the lower bell crank, and the linkage from the lower bell crank to the 727. For shifting the trans, I would need the necessary linkage from the column to the chassis mounted cross bar to the trans., not sure if the original s6/904 cross linkage bar will work for a 727. Will any of my existing parts work, or will I need to find everything for a 70 Dart 340/727/auto/column shift? Thanks in advance FABO friends.
