rick_rawker
Can someone look and see where the oil send unit is on a slant please. I am re-wiring after a v-8 swap. The grey wire is MIA.
no, it's up there ^^^^^^
its on the oil pump facing the transmission on my 69 170.
also your last line is very confusing witch prompted kuda's responses. if you would enplane what your doing you could get better ones.
As above... it is on the oil pump, just under the filter mount and facing to the rear. KK must be in a 'playful' mood this eve.... LOL
whatever dude
just peel back the factory taped covering all these wires, and find that grey oil pump wire.
Usually a littlle more info is needed... :banghead:
If you ask a general question, you get a general answer... :glasses7:
Luckily you got the right answer that you were looking for.
thank you !
