what luck have you had with lokar accel cable and how would it be installed at accel pedal or is there a better solution for a cable on eldebrock victor intake small block
I have one on my car. If I remember correctly, they come with a Clevis at the pedal side...remove this and there will be a standard style ball end that will work fine with your pedal. I did also have to use some washers at the firewall and cut it shorter to get the right length, but its been on the car for 7 years (I also have their bracket) and it works great.
