Lokar kickdown linkage for torqueflite
shutudown4
torrance, CA
I spoke with a Lokar tech guy
Regarding their 727 torqueflite kickdown linkage cable
He’s not sure if his kit will work w a starshifter
I’m running a 6 pack
He also said I might have issues with the manifold bracket for the 6 pack
It will work with a 4 barrel
But I want the 6 pack
Anyone have experience with this situation?
So much for wanting to drop the motor in this weekend
Shutudown4
I have a six pack installed temporarily on my 340 with a Lokar cable and a 727.
I had to fabricate a pulley and a primary cable to pull the kickdown cable because there isn’t a lever on the throttle linkage to pull the cable forward while the throttle is opened.
I’ll try to post some photos later on.
My long term fix will be installing a RMVB and not have a kickdown cable or linkage.
Cool
Send some pics
I’m stressed about this situation
It’s really holding me up
If u can send them asap
The tech guy wasn’t the greatest in helping me
What I want at this point is the 4 barrel bracket to possibly figure out if it can be modified
Happy holidays
Shutudown4
Here is what I did, I wouldn’t rely on this for long term as I said, I’m going with a manual valve body.
But this does work enough for me to dial the carbs in.
You can purchase the correct linkage for about 350-400.
I’m planning on selling my six pack and keeping a tunnel ram set up.
This is a manual setup so, the fuel lines are on the driver’s side.
I had it on with my other six pack which is a vacuum operated. There is more room for the cables with that.
I know I didn’t really address the question about the Lokar bracket. I have been using one on the tunnel ram but it was easier to use the six pack bracket for what I did.
Send me a pm if you want to talk over the phone.
When all else fails, you can clamp the Lokar cable to the gas pedal.
Signed, the lunatic with a 4.6 Ford throttle body on a slant six.
I just got a bouchillon kickdown setup
Super easy to install
Anybody w a lokar setup throw it away
Immediately
It’s only made for a 4 barrel
Bouchillon works w six pack without any problems
Shutudown4
Been using a B&M star shifter on multiple cars for 30 years or more. I can't figure out how the cable operation of the shift mechanism would have any effect on the kickdown mechanism that you would use - while they are next to each other on the trans they are completely different systems that don't have any effect on one another in terms of how they are actuated
Immediately
Shutudown4
Post some photos.
Immediately.
