gdizzle
Update #4:Here is my re-work of the connection. I also changed the spring at the tranny, the one they put on was too tight. Seems to help. I didn't modify the tranny bracket, no room. I now get kickdown, though it takes about 1 second to kick in. shift points are good, so I am hesitant to tighten the cable any further.
Also, can anyone explain what the difference is for the adjustments on the Lokar? #1 is overall length of the cable at the set screw bit. #2 is the screws at the bracket (lengthen or shorten the distance from the bracket to the carb throttle).
what is the difference? Only other thing I still may mess with is the angle of the Lokar at the carb, it sorta rubs the wire. I would prefer a straight shot for that cable to the carb arm. Ideas?
