Longer rear wheel studs found, with part number.
Mikk
Member
Udora, Ontario, Canada
I needed longer 1/2" studs to fit aluminum wheels on my 7.25" axle (I have an axle from a '73 Dart on my '66 Barracuda). Seems like others on the forum have had the same problem, but couldn't find anything suitable. After much searching, looking at specs (some contradictory), and one incorrect purchase, I found some! Dorman 610287 are a longer replacement, although the shoulder may or may not be a bit long for plain steel wheels, but they work perfectly with aluminum wheels. I believe the studs are for an early 2000's B-series van. Pictures attached.
Thanks. Hopefully helps others, I've got 3"studs in my cars that I drag race.
I like those wheels. They look a bit like the 1969 recall wheels.
Thanks, I thought they looked like the 'recalls' as well, that's what sold me on them. Here's a picture of the whole car. I converted the front to 1970 Barracuda 10x2.5" brakes. Better than the 9" brakes I had before, plus I got the big bolt pattern. I know, disks are better, but I got the hubs, spindles and brakes for $100. The rear axle has 10x2.5 brakes as well.
