Longer than Stock Wheel Stud
jefflock
69 Dart 408 10.08 best pass so far
Kansas
Does anybody know if there is a longer than stock stud made for Yukon axles? I know there are 3" studs for racing but I don't need all that stud sticking out.
Jeff do you need press in studs or screw in studs? Summit has a nice selection of all sizes. I bought a set of 2" long screw in studs from them and can still use my acorn lug nuts with them. The only problem I ran into was the axle with the adjuster (pass side) has less clearance so they hit the parking brake strut. I took the strut off and used a cutoff wheel to trim about 1/8" off the strut then it cleared. Some screw in studs have allen heads which clear without doing any modification. I didn't know this when I bought mine or would've got them instead.
Lookin for press in studs. I"ll check Summitt and see what they have.
if you go to a good parts house and bring one of the studs they can find one for you. they all should have a dorman book that all you need is to measure the knurl diameter and length you need. they have a great selection of sizes.
