I'm looking to find some parts for my project.
-D60 carrier anything but open.(running 4.56 gears so need a carrier that will work)
-D60 housing ends.
-SFI approved flywheel for a 360, good clutch for the same.
-Stroker pieces for a 360(408 preferred internal or external balance)
-drop spindles for a body
-Ididit steering column w/o key
-good door hinges
-tubular upper control arms.
I would like to possibly trade for any of those parts:
complete abody front disc brake suspension, Sway bar, big bolt pattern, Power steering box, good ball joints. Bolt in good(not pretty but would function fine in a driver) slant 6 kmember. I'm willing to ship anywhere. I'd prefer not to part the spindles off but depending on what I get in trade.
18 spline input shaft 833 4 speed with a 4.8" input bearing retainer. Good shape. bolt in. again willing to ship anywhere and I'll crate it up nice and tight so it gets there in one piece.
A body steering column non tilt, good shape.
A body bucket seats
A body auto console
Slant 6 stock torsion bars
7 1/4 limited slip rear sbp, needs new seals.
Edit: I also have some manual transmission parts. I have 4 speed pedals, a zbar, slant 6 aluminum bellhousing.
I also have a bunch of parts I don't plan on using in my dart. Heater box, 2 instrument clusters, dash trim, factory radio, I'm basically not using the stock dash at all and switches etc. will all but up for grabs so if you need it I'll try and check if mines in good shape.
-D60 housing ends.
-good door hinges
A body bucket seats
A body auto console
