[Found!] Looking for Magnum Edelbrock Heads 61775 and Intake 7577
GoneShawn
Good afternoon Everone,
I know its a long shot, but Ill ask any way, Im looking for an Edelbrock Magnum Intake and heads
Thanks!
Thanks!
Those heads and intake are in stock at Summit. Is there something specific that you're after that keeps you from buying them there?
I was hoping to find a lightly used set for some cost savings. Ended up doing a little more research and decided to buy the trick flow 190 heads new, along with the track heat intake. thanks for the solid advice, along with some discount codes, it was probably worth it.
