looking for the rear window sheetmetal
wireweld
South Dakota
I am looking for the bottom of the rear window sheetmetal about 8 inches up on each corner to all the way across the bottom of the window. I will be putting the vinyl top back on so I will need the joint between the window and the trim rivets. Thank you for any help.
i might be able to help, I have a 72 scamp that is all cut up. are you able to post a pic of the area needed?
