Looks like K1 has a 10% off deal going on.
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
Got this email tonight.
I'm planning on building a big inch small block engine for my 68' Barracuda. I already have an X block and Eagle H beams (6.123). Planning on using Ross 12.5 pistons. I know Molnar used to advertise a 4.125 crank. OHIO crank has a 4.180 advertised as well as Hughes. I've heard availability may be a problem with Molnar. Ohio crank has a rotating assy. using the 4.180. I live in the Detroit area and Molnar is in Grand Rapids. Maybe I should contact them and find out if they have anything off the shelf that I can get. I follow A bodies from time to time and seen your postings. You seem to be 'in the know' as far as racing parts goes. Any advice would be appreciated. Any type of deal would be great but I'll pop for the high buck stuff if I have to. No rush. A new furnace & AC, along with a dental emergency and summer taxes left me short on $$$ for the short term.
I never really check out the package deals as I piece mine together. I shy away from
Stuff like 4.180 cranks as you really limit your options. I like simple.
