lost it
famous bob
mopar misfit
okla
I realize it would be a stroke of luck for one of you to have this bolt out at this particular time. but, I`ve lost the bolt that ties the brake pedal and the brake rod together. the hole in the brake rod is .575 diameter, I can`t find anything in my garage that even looks like it will work. the car has been down a long time.
there isn`t a good pic of it in the service manual that I`ve got either.
do any of you know or remember exactly what this bolt or pieces look like, or even draw one "if your computer smart" and post it ? would sure help,I`ve looked all over the place and can`t find it. need to bleed the new brake system and this has me hung up!----------------------------thanks, bob
-------------------------------:banghead:sorry for the long post---------------------
I will look when I get to the garage. I have a 66 I switched to all disc and stock pedal. I will see what I have. Bob
It is a long shoulder bolt with an o-ring (to hold it in place, I guess). I've got some out at home, might even be able to find one or two...
