Lost transmission bracket
dstan
prichard, Wv
I sent my truck off to get the transmission a while back and the shop lost one of the brackets for the shift linkage. I can't find one online that looks like the old one did and was hoping one of the resident mopar enthusiasts here could tell me what transmission it was actually from. It has more of a downward offset then the ones I've seen on 727's before. (It was being used on a 727 swapped into an 89 d100). I've attached a rough model of it.
That looks just like what I've removed from several truck 727s over the years. There are also brackets with a shorter leg on them, maybe those are for column shift cars or vans, not sure. Bushing in the lower hole, for the horizontal shaft that goes between the frame and trans. Just pulled one with the 727 from my 1980 D150 last week.
I would think that would be very simple to make.
Alright. If it's an origional 727 piece I'll keep scouring ebay until I find a replacement. Thanks everyone for your input.
