Lovemaking tips for Seniors
Mark Wainwright
Ontario Canada
1. Wear your glasses to make sure your partner is actually in the bed.
2. Set timer for 3 minutes, in case you doze off in the middle.
3. Set the mood with lighting. (Turn them ALL OFF!)
4. Make sure you put 911 on your speed dial before you begin.
5. Write partner's name on your hand in case you can't remember...
6. Use extra poly grip so your teeth don't end up under the bed.
7. Have Tylenol or whatever you use ready in case you actually complete the act...
8. Make all the noise you want... The neighbors are deaf, too.
9. If it works, call everyone you know with the good news .... even if its 8PM... !!
10. Don't even think about trying it twice.
