Lower ball joint removal 64 dart gt convert
Suspension, Steering and Chassis
  1. BlooDSMeaR
    BlooDSMeaR Well-Known Member
    53
    51
    Jun 23, 2017
    Medford Or.
    Local Time:
    1:12 AM
    I am helping my father in law rebuild his front suspension on his 64 Dart GT convertible.
    I am needing info on how to get the lower ball joint assembly removed from the drum brakes. I have used my dewalt impact to try to bust them lose. No joy.
    The rest has came apart with no issues.
    It's a California rust free car.
  2. Bodyperson
    Bodyperson A little sketchy
    2,575
    2512
    Nov 26, 2015
    NW MONTANA
    Local Time:
    2:12 AM
    Your "info" request is a little vague. A better description of the situation might generate a better response.
  3. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    51,996
    20070
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    4:12 AM
    Breaker bar and a pipe!
  4. Bodyperson
    2,575
    2512
    Nov 26, 2015
    NW MONTANA
    Local Time:
    2:12 AM
    Your info offering is a little vague. A better description of the operation would be appreciated.:lol:
  5. halifaxhops
    51,996
    20070
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    4:12 AM
    The two bolts that hold on the lower ball joint rusted in?
  6. hemi71x
    hemi71x FABO Gold Member FABO Gold Member
    4,697
    1266
    Dec 22, 2009
    Rancho Cordova, CA
    Local Time:
    1:12 AM
    Lowers are a piece of cake.
    Just nuts and bolts to remove, and a pickle fork to remove the stud portion out of the lower control arm.
    Is by chance your posting a miss type, and your really meaning "UPPER" ball joints?
    • Agree Agree x 1
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,118
      646
      Apr 19, 2010
      San Jose, California
      Local Time:
      1:12 AM
      You need to borrow a better impact gun.
      • Agree Agree x 1
      • BlooDSMeaR
        53
        51
        Jun 23, 2017
        Medford Or.
        Local Time:
        1:12 AM
        Are the bolts backed up by a nut on the inside of the drum brake housings? Do I need to pull the brakes apart to get to them?
        • Thanks! Thanks! x 1
        • Murray
          1,118
          646
          Apr 19, 2010
          Local Time:
          1:12 AM
          Yes, this is a nut and bolt.
        • BlooDSMeaR
          53
          51
          Jun 23, 2017
          Medford Or.
          Local Time:
          1:12 AM
          Sorry for the late reply. I have finished the suspension rebuild.
          In order for me to remove the lower ball joint. I had to removed the brake drum, and undo the lower portion of the brake assembly to get to the lower ball joint nuts on the inside of the brake housing. After every thing was done it went back together with no drama. Thanks for your guy's help!!!
