Lower boot under the console
Actually, I have the boot that attaches to the bottom of the top plate on the console. I need the boot that covers the oval hole in the floor hump. This boot helps keep road noise and engine heat from getting into the car.
Most of them I have seen are just a standard non console floor boot on the bottom. I assume that is the correct boot seeing it will screw right down and is the same pattern as the top of the floor tunnel.
