trad07
Active Member
I bought a front end rebuild kit and installed everything but the lower control arm bushings because I had no press. I found a garage who pressed the old out and the new in for $75 dollars. The bushing on the passenger side is great but, on the one on the Drivers the shaft turns when I try to tighten it. If I hold it on the shoulder with a pipe wrench it tightens. Will the torsion bars work properly or did the garage give me the shaft?
