vallianted
Hey all hope I'm in the right forum.on the home stretch completing my v8 swap in our 65 Valliant rag top.put in a 318 with a champion rad and was wondering which rad hose would fit on the bottom?
Is the outlet the same O.d as stock?Hey all hope I'm in the right forum.on the home stretch completing my v8 swap in our 65 Valliant rag top.put in a 318 with a champion rad and was wondering which rad hose would fit on the bottom?
sorry the outlet location is on the right side and yes I have a aluminum water pump.What about the outlet location ? And are you using the aluminum water pump housing?
You nailed it.had to trim 3 inches off the top and it fits perfect.Since you're running a late model pump with a matching radiator, I'd start with a standard late model radiator hose. May need to trim for a perfect fit.
This one for a '70 Dart 318:
More Information for CONTINENTAL 60880
