[WANTED] Lower Shift Linkage Rod for 727
DartThis74
Houston,Tx
As seen in the photo below. I need the "Lower Rod" and the "Swivel Assembly" to complete my floor console shift set up. I would greatly appreciate any help someone can provide. I am very close to finally getting my car on the road and this is a major component I'm missing. Thanks in advance everyone ! I live in Central Texas zip code 76579.
attachment.php
-Aaron
Oh wow I guess it was your photo. I just found it earlier today and thought it describes what I want really well haha thanks !
For what year car or what year are your other linkage pieces? That rod in the pic is for a 68 and back B-or C-Body not an A-Body, many of those pics in the service manuals are for reference of the part only and are not correct many times by model application. There are differences in some years for that lower rod. You can usually use all the same linkage pieces on different years of A-Body but if you mismatch pieces many times they will not function correctly.
I'm sorry, I never was notified of posts on here. I am using this is a 74 dart that has a transplanted 727. Floor shift was not factory, but was added by me.
If you post up some pics of the other linkage pieces you are using we can help you get the correct lower rod. The shift lever on the trans also has to match the linkage pieces you are using as well to function correctly
