Lowering the rear
SRT_DSTRHOLC
USA
I want to lower the rear of the duster, but im not sure if the springs will hit after i lower it.. is there any suggestions? Can i put the spings back to normal after i lower them if they hit?
The fastest, cheapest, easiest way would be to use lowering blocks. 1" blocks might be all you need - and it's reversible. I don't see how the springs would hit anything while lowering the rear.
Flip over your front spring eye hangers & oval the holes a little to fit.Lowers the rear about 3/4" - 1", cost: $0.00 just a little time & patience.
