Magnum engine/spark plugs.
Abodybomber
Breaking street machines , since 1983.....:)
Legendary Member
Arroyo grande ca
99 Magnum,stock heads.Mild roller(224@.050,114l/c)Air gap intake.Headers,summit exh.MSD ignition(6al).My 750 double pumper ko ed the power valve,flooded the plugs.Had the champions in it to start.Not a big fan of Champion plugs,looking for a recommendation,thanks.
I like NGK V Power, go 1 step colder for your set-up, set the gap around .042-.044" NA, -6 will be the heat range you want. Don't remember the prefix #, They sell them at O'Reilly's.
