Magnum head bolts on an LA
74desertduster
Tucson AZ
Anybody know if Magnum head bolts will work on an LA engine with LA heads? I have a new set of Magnum bolts and would like to use them if I can.
Thanks!
At least some of them will be either too short or too long. Magnum uses only two lengths and the LA I thick uses 4. When I compared them none were exactly the same lenght between the two engines.
