moturbopar
Hi all im wanting to put a set of magnum heads on an LA 360 block. I have the heads, pushrods are ordered and I also have magnum head bolts. A magnum performer RPm is also on hte way. Im still wondering a couple things about the swap. First can you use regular La head gaskets with the magnum heads? also is there any cheap 1.5 ratio rocker conversions available. I have the stock 1.6 stuff but not sure how well it will work with the voodoo 268 cam. The 1.6 ratio rockers put intake lift at .527 and ext is .547. the guides have been machined for clearance, I just dont know if the factory rockers can handle this.
