straightlinespeed
Sometimes I pretend to be normal
For those of you out there running magnum heads on a LA engine. I have a question regarding the valve springs. Im running a Comp Cams XE268H cam and there recommended springs are the 901-16.
I had a question for Comp and the valve springs came up. I assumed I had there recommended springs installed on my heads, but they told me that the 901-16's will not fit magnums heads.
So curious, as to if any of you are running a similar set up as me and what you used for springs?
