[SOLD] Magnum Hydraulic Roller Cam
subcom
South Florida
Oregon grind #1357. Specs here.
Hydraulic Roller Camshaft Specifications
Great cam for you Magnum swap guys. With EQ heads and a stock 5.9 Magnum my car went a best of 7.90 in the 1/8th N/A with this cam.
Video of first start of the engine with this cam. Has a nice idle.
$175.00 shipped to the lower 48. PayPal only please. Located in S. Florida. Thanks
Sorry, what are the specs?
Sorry for the chart, but you should be able to get the numbers.
GRIND DURA@.050 DURA@.006 LOBE LOBE CENTER LOBE LIFT VALVE LIFT @ ROCKER ratio
INT EXH INT EXH SEP INT EXH INT EXH 1.5 1.6
1357 230 236 284 290 112 108 116 322 322 483 483 515 515
Were you able to use this cam with stock magnum lifters and intermediate shaft? Or does it require a bronze gear / aftermarket exposed wheel lifters?
I used the pushrods I listed above with the original lifters, rocker gear and intermediate shaft.
I'll take the cam if it hasn't been sold already. PM sent
