[SOLD] Magnum No-A/C Alternator Bracket
JoesEdge
Downey, CA
Hey there Magnum fans! I have something for ya!
Sure, Hemi's are the "in" thing to swap in these days, but Magnums are plentiful! The wrecking yards are full of Magnums waiting for their 2nd life to begin.
Are you planning in swapping one into your A-Body? So you don't have A/C? Don't even think of running that unsightly Dorman A/C idler pulley!! Instead, I have something better for you!!
I have here a factory No-A/C alternator bracket with idler pulley for the low, low cost of only $60.00 bucks shipped to you door via the good 'ole USPS service (in a priority flat rate box). Also included are the bolts to attach it to your beastly Magnum power plant!
This work great with the Magnum power steering bracket off a Dodge van. It will tuck the power steering lower and not into the battery try like the truck bracket does.
NOTE: Magnum valve cover not for sale!
DETAILS
Items:
Magnum no-A/C Alternator Bracket (with idler pulley and bolts)
Ships From: Downey, CA
Cost: $60.00 (shipped)
Thanks FABO! :)
