Krooser
Building Chinese Free Engines since 1959...
I have a set of 8 - 2.02/8mm Si stainless steel intake valves. New never installed. $75.00 shipped to lower 48.
I have a set of new small block Mopar hydraulic lifters... NIB... Bought from Clay Smith Cams. These are the wire ring not the snap ring style. Great for stock or mild performance use. No EDM hole. $90.00 shipped to lower 48.
Set of 5/16 x 3/8 rocker studs to convert a Magnum head to adjustable rockers. Comp brand #4542 IIRC and Comp guide plates #4816. Both parts numbers $70.00 shipped in the lower 48.
One pair Magnum heads machined for adjustable rockers. Have been mag'd. Will need to be cleaned and get a valve job. $125.00 plus shipping.
Elgin valve springs 99022k 120/325 $55.00 shipped in lower 48.
Howard's valve springs 98443 140/325 $70.00 shipped lower 48.
