[SOLD] Magnum Valve covers
RAVano
Ct
These are welded polished aluminum valve covers a had on my Magnum. No leaks at all when installed. I’ve never seen another pair like these before and not sure if the brand. I’ll take $50 plus shipping.
As you know, these fit a magnum engine, but they are designed for an LA engine
(Simply count the bolt holes)
They are actually designed for a Magnum but will fit a LA.
If you bolt them up to a LA the Mopar symbol would be upside down. Also, they have a notch in the valve cover that clears the magnum alternator stud.
