magnum water pump
no magnum water pumps will not fit LA timing covers, also there reverse rotation
you either need all the pulleys and parts from a magnum engine or all the pulleys and parts from an LA engine can't use some of one thing and some of the other
I have a magnum timing cover if your in need of one
Ok thanks, i pulled the front accesories minus pump and cover from a magnum yesterday and was just curious. Should have asked before so i wouldnt have to make a second trip to the junk yard lol
