[FOR SALE] Mahle SBM 4" Stroker pistons 4.04" bore
MRL Performance
here
I have a set of Mahle FLAT TOP 4.040" Power pack pistons for sale. These are for a Mopar pin .984 and 4.00" stroke crank. These are the best off the shelf pistons. Come as a kit with pistons, rings and pins/locks. The block provided me for this build would not clean up at 4.040" so I need to unload them. These retail at $700+!!!!!!!!!!!!! See here http://www.jegs.com/i/Mahle/644/SBM460040F05/10002/-1
Get this set for $600 and save $100!!!! I will pay the shipping anywhere in the USA.
what engine for dude?
Any Small Block Mopar with a 4.040" Bore, a 4.00" stroke, a 6.123" rod length and 9.600" Block Deck Height.
1.460" Compression Height
6.123" Rod
4.00" Stroker
2.125" Rod Journal Diameter
.984" Piston Pin
-5cc Piston Crown Volume Flat Top
450 grams advertised without pin/rings/clips
Made from Low expanding 4032 Forgings recommended piston to wall clearance- .0025-.0033"
1.5mm/1.5mm/3.0mm file fit ring pack, better sealing and lower friction than thicker rings sets
Coated Skirts for tighter piston to wall clearance and anti-scuffing
Coated piston pin bore and ring grooves for protection during break-in
Part Number SBM460040F05
