[SOLD] Mallory Ignition Components
Rocket
CT
Mallory Comp SS 32 Distributor for Small Block
I have a nice Mallory SS 32 distributor and Mallory Pro Series 8 MM wires with aluminum wire separators. Very little use. Features:
CNC-machined billet aluminum housing
* Ball bearing upper and lower bushings for maximum stability at high rpm
* 208 series distributor cap with spark plug wire retainer
* Easy-to-adjust mechanical advance
* 2-wire, Ford-style magnetic pickup
* Requires CD ignition system
* Can be converted to vacuum advance
Price is $190 shipped in the lower 48 states.
Mallory HyFire 6AL CD ignition box. Little use.
Specs are:
Ignition Box Output:Capacitive discharge
Circuitry:Digital
Rev Limiter:Yes
Timing Retard:None
Data Acquisition:No
CD Voltage Output to Coil:520 V
Current Draw:0.6 amps per 1,000 rpm
Spark Output (millijoules):135 Millijoules
Minimum Operating Voltage:8 V
Maximum Operating Voltage:16 V
Price is $125 shipped in the lower 48 states.
Mallory ProMaster E series Coil. Very little use.
Specs Are:
Coil Style:E-core
Primary Resistance:0.500 ohms
Coil Internal Construction:Epoxy
Coil Color:Black
Maximum Voltage:51,000 V
Turns Ratio:99:1
Secondary Resistance:8.9K ohms
Inductance:5.6 mH
Peak Current:260 mA
Spark Duration:250 uS
Price is $50 shipped in the lower 48 states.
They were used 2 summers and have been in a box for a couple of years. All in very good shape.
Dont diss Mallory, I run it and never had an ignition failure. Good stuff. Bump
