Gus Loza
i have a 69 dart with manual brakes and i removed the 4 bolts that holds the m.c. to the car and i cant get the pushrod to come out of it. i tried to unbolt it from underneath the dash but it was hard to get a wrench to hold the other side of the bolt to loosen it. then i pulled back on the brake pedal and it ripped the rear piston out of the m.c.. so the mc is off now (was replacing it anyway) but still have the piston stuck to the pushrod. any advice?
thanks
thanks
